Some issues... need help`
ViciousLSD
4
Ok i was on the 2.1 version and rooted it with no issues with superoneclick. Yesterday i updated to 2.2 and i love how much faster the phone is. I just tried to install busybox for titanium back up to work and busybox isnt working. It says superuser needs to grant permission for busybox to work but how the hell do i give it permission to work? The phone has been re-rooted with superoneclick and it says its rooted..... any ideas?
I've had similar problems in the past- try rebooting the phone, and then firing up TiBu.
Tibu should request su access, which in turn should pop a window on the screen from the Superuser utility asking you to allow Tibu to gain su privilege. Confirm and select "remember this choice" or something similar.
Things that could break this:
1) USB debugging (think it needs to be on, but not sure)
2) USB cable unplugged (think this needs to be true)
3) Are you really rooted (try again with one-click)
4) Do you have superuser utility installed (check under applications)
Hope this helps, consider pressing thanks if it did, it makes me smile.
AoN
Thank you for the reply and suggestions. I tried them and it still didnt work. It says my phone is rooted but i cant use TiBU because busybox... i go into busy box installer and it says to allow it through superuser? I dont see and option that will allow it... any ideas?
and for TiBU i allowed it and it still gets denied...says please verify that my rom is rooted and includes busybox and try again.
04ijordan
