Sony Xperia Z3 led while charging
johnnyshinta
2,666
22
While charging my phone the led is orange until about 90%. From 90% on the led is green. Normal?
Re: led while charging
Well, if I talk about my case then its read uptil 50% and then after 50% it turns orange and lastly after 90% it turns to green. So, I can say that would be okay and tell me who cares about the LED glowing until or unless a device is charging good ! I would rather say don't worry too much about what color LED is glowing !
Every other phone I've had would glow orange until fully charged then glow green till pulled off the charger. It doesn't bother me I was curious if jus normal for Sony phones. This is my first one.
Yes. I had to download the instructions from t-mobile and it does state this.
Doesn anyone have an idea on how to disable the LED while charing.
This is really annoying me at night.
I'm fortunate in that my bedside table is at a height it doesn't bother me. But otherwise I'd have to charge it face down at night.
Use a piece of electrical tape.
Hm ok, valid and maybe the way I will have to go in the end. :) But I would really like to avoid this. Especially as I like the notification light as feature in general. Just hating it at night time.
Well I would really like to continue using a dock. And even without dock, facing down the mobile is not a perfect solution for me, as my white night table is reflecting the light ... ;(
Although this weren't the replies I was hoping for, thanks a lot for your feedback Ulver982 and JBeffX.
Just fyi:
I finally found an app called "disable charging led" solving my issue (play.google.com/store/apps/details?id=de.deck36.fyled&hl=de )
Bad thing about: It was not for free :(
Good thing about: This app works out of the box and without the need of root.
Thanks for your feedback again!
Marabishi
