Sorry! Process System Is Not Responding
drmaj
Hi Guys,
I am very new to the Android scene. I am coming from an iPhone background & more recently WebOS.
A friend of mine gave me his HTC Desire with a broken screen. I ordered a replacement from eBay & put it in today. Everything worked great once I powered it up. I put my sim card in, put an 8gb micro SD card in, made phone calls & sent text messages etc.
However, problems arose when I was prompted to update my version of Android over Wireless (OTA?).
Upon reboot, the phone gives me an error:
Sorry! Process System Is Not Responding {Force Quit} {Wait}
I have no WiFi, no 3G & now the phone reboots every 5 minutes or so. I can open the recovery menu, but if I select the 'Recovery' option it just gives me the 'Red Triangle' with the exclamation point. No menu or text.
Some info (if it helps):
Baseband Version: 32.41.00.32U_4.08.00.09
Build Version: 2.10.405.2 CL226611
Software: 2.10.405.2
HBoot: 0.83.0001
Radio: 4.08.00.09
I am not sure if this phone was previously rooted (doubt it), but im stuck and have not found any information that relates to my problem. One article I found did have the same problem but was resolved using the recovery menu, which doesn't work for me.
I have tried other things such as doing a factory reset etc etc, but to no avail.
Has anybody come across this problem before?
Thanks,
MaJ.
Hi
My HTC Desire went into loop with "Process system not reponding"
Press button for force stop or wait.
Repeated message all day, i could not access the phone at all.
No turn on or off so i couldn't do the the suggested fixes i found on the net.
But had a brain wave that i can't seem to find anywhere mentioned.
HTC is a small PC, PC buggers up you do a reboot. You pull the power plug
out of the PC to ensure a clean start.
Did the same to the phone, pulled the battery out for 10 minutes.
Phone did a reboot and seems to work fine.
Worked for me.
Dave
vike myke
