Sound and notification crashing Settings
HeyMcFly
4
Just updated to 5.0, tried to go into "Sound and notification" in the settings menu, however whenever I touch it, Settings crashes. I've tried rebooting, wiping the cache partition, and clearing Settings data/cache. Any other suggestions?
Sounds like a factory reset may be all that's left as you've tried the standard fixes already.
No one wants to do a reset but it improved my phone so much after the update. Use keis and 90ish percent will be just as you left it when you restore.
yep, factory reset fixed it....annoying but at least solved, also solved my battery drain.
alwinnn
