Sound drops out on Android 2.1
bakerjs
3
First post. Please be nice.
I finally took the plunge and rooted my Sprint Hero a couple of days ago, and since then, I've tried three different ROMs: a) 2.1 leak; b) 2.1 leak w/ custom memory management; and c) Fresh ROM.
Unfortunately, I've had the same problem with all three: Unexpectedly and without warning, the sound on my phone will suddenly drop out. Sometimes this happens while I'm talking on the phone, and other times it happens when I'm listening to music. I have to reboot he phone to get the sound back, but a few minutes or a few hours later, I'll inevitably lose sound again.
Does anyone else have this problem? And, more important, does anyone know how I can fix it? One more tidbit: This never happened on my phone with 1.5 before rooting.
I finally took the plunge and rooted my Hero a couple of days ago, and since then, I've tried three different ROMs: a) 2.1 leak; b) 2.1 leak w/ custom memory management; and c) Fresh ROM.
Its a known problem with 2.1 some people have it sum don't. I don't think there is a 100% fix yet.
It's a kernel issue.
The fix is to use the kernel designed for the Eris if your phone is affected. Yes, this means there are hardware differences in some Heros. Some have their own chip for sound, some use the same model as the Eris.
Very easy fix, but you lose the ability to use the light sensor and the jogball light. I'm building a fix with another developer, as soon as it's properly tested there will be a patch available for users who have one of the ROM's here.
I have it in testing right now, I have to let the other fellow test it as well. If he says green light, I'll post it here.
I had that problem for the first time the other day, and I've been running 2.1 for an eternity. It seemed to be an isolated issue as I haven't had it since. For me, it seemed to have been something with using a bluetooth headset and how I ended the call. Not saying thats the SAME issue, just what i noticed.
Different issue, but infuriating none the less lol.
Sometimes you get the same thing after unplugging a wired headset too. I was hoping that got fixed in 2.1, but apparently not :mad:
Interestingly enough I did have this problem with Fresh and DamageControl 2.0.5 but since I started using 2.0.6 and now on 2.0.7.2 I have not had any issues. I think Fresh has a patch out there. it's not hard to find posts about loss of audio over on the xda-developers forum.
Which patch did you use? AudioFixRC or AudioFixERIS ?
I was curious about tryin 'em both but not sure if either will screw up my phone.
Update #2: The first time, I tried AudioFixERIS (thinking my phone was a candidate for this version), and no dice. However, a couple of days ago I tried AudioFixRC, and voila ... no problems since then. Looks like I'm all set now.
I ended up flashin the ERIS patch, and that resolved the audio issue. Yeah, no trackball light and auto brightness, but meh, no biggie :p
kos123q
