Sound issue?
madkoda12
262
Hey there guys, I just got the Nexus 6 through T-Mobile, I LOVE it! But I had one question that I wasn't sure if the issue is really an issue or just something with the sound file used for certain sounds.
Basically it seems like the system sounds have some sort of buzz in them after they chime. For instance after waking up the phone there's like a static noise for a bit after the sound finishes, and most notably when using tumblr and I favorite a post I hear it also. I have the system sounds set to max and the only time I hear the static noise is after one of the system sounds. Also just checking it again it seems to be only the top speaker that does this.
Is this normal or should I replace my device?
tombwiz14
