Sound on key press
santoro1200
10
My sound on key press on the stock android keyboard is not working(no sound) I have it checked in settings..I have vibrate on key press checked as well and that works fine..any suggestions?
If you go to language & input.... android keyboard settings... advanced settings... adjust the keypress sound volume settings. Also make sure you have the volume turned up on the phone with the volume rocker.
Other then that... if you're still having a problem.. try rebooting the phone.
I really appreciate the help but i do not see that option in advanced setting (in android keyboard setting) ive added a sceen shot attachment to shotw what advanced settings has..
toolpunk
