sound pac-man notificaton
louis14
13
How can I adapt the sound of my pac-man notifications.
Now the sound is the same as my sms and I don' like that.
My android is mashmallow 6.0.1
In the general app settings I can only disable notfications of pacman
If the app only gives you a toggle for notifications on/off, but not an option for a specific sound, it will always use the System Default. You can change that one in your device's Sound settings, but that will apply for all apps that use said sound.
s3solnduck
