Sound Set Question
Flavy
103
5
How do you change the sounds for Email, Message, and Calendar notifications in the sound set? I was able to change the sounds for notifications and ringer, but I can't find where I can change the sounds for Email, Messages, and Calendar.
Each app has its own settings where you can change the sounds
There are a few ways of doing this.
On the home screen, click the bottom right button with the hand pallet and brush. Scroll down to sound set. This will allow you to create a custom set up or use the stock seetings.
If you do not choose sound set, all the available settings are right below it.
Also, if you go to Menu -> Settings -> Sounds it will have options to change things there. Also if you open your messaging app, click menu -> settings -> sounds / notifications and you should be able to change it there.
How do you change the sound set for email? There doesn't seem to be an option within the Email app to select a ringtone. I found the one for the Calendar notification, but still can't find a way to change the sound for the Email notification. Thanks again for all your help.
What E-mail app are you using?
If you go to Gmail
Gmail -> Menu -> More -> Settings -> scroll down to "Notification settings" and the second choice is select ringtone.
For me I set the default notification sound for the phone as what I wanted email to be, since in the HTC app there isn't the option to set the specific sound.
Sent from my Thunderbolt using Tapatalk
If you go to Gmail
This is for the HTC Email app which I use for my Hotmail account. I set my default notification to Simple Low, but the Email notification seems to be hard coded to Alpha.
In the HTC email app while on the account you want to change go to menu/more/settings/notifications there you can set each what you want for each account.
There are only check boxes on which notifications you want. I don't see where I can select the specific ringtone.
Does anyone know how to or if it is possible to import notification sounds? I know you can import ringtones but can't figure out how to be able to use different sounds than the ones that come on the Tbolt. I've tried changing the name on the folder that I have my sounds I'd like to use, but that isn't working either. Thanks in advance.
slimmy0
