• Welcome to the all-new Android Central Forums! - We're still moving some things around, so you may see a few quirks here and there, but we're working on getting things fully completed as soon as possible. For now, take a look around, and if you run into any major issues, please let us know in this thread!
sound when turning phone on
nonie
1,552
7
Is there a way to turn the sound off when turning s5 on? Looked in setting, but don't see this option.
Rev2010
852
67
You can't turn off just that sound without being rooted afaik. You can however lower the volume slider for System Sounds down to zero, that does it but then you won't get system sounds. Never needed them myself on my S3 since notification are a separate slider and I have all the touch sounds turned off anyway.
*EDIT - just tested on my S5. I have the System Sounds setting down to zero too and when I reboot I get a fraction of the AT&T sound before the volume slider loads and kills it it seems. So not a 100% fix on the S5 but it was on my S3. Just seems to be the order in which the OS components load or something.
Rev.
f308gt4
216
Are you talking about the startup sound? If the phone is on mute or vibrate, the startup sound does not play. I'm on Verizon if that makes a difference.
nonie
1,552
7
Yes, the start up sound, sorry couldn't think of what to call it. I am on att.
Going to try what, Rev, suggested.
nonie
1,552
7
I tried, Rev' suggestion of turning volume on system down to 0, and no sound this morning when I turned my phone on.
thanks, Rev.
Joseph Coope
47
if u change the mode on to silent mode then the start up sound will off. Try this suggestion please
