Spare parts
NHBass39
840
7
Anyone try it on the tab yet? Just wondering how it works on the galaxy tab resizing apps.
It does what it's supposed to do, but the process is a bit unintuitive -- you have to uncheck compatibility mode, recheck, reboot, then uncheck it again and reboot.
I haven't run across any apps that don't stretch, but I did notice that Zenonia is distorted in full screen, probably because Spare Parts stretches to fit and doesn't care about aspect ratio.
I also used it to run Droid Comic Viewer in full screen, but I ended up sticking with jjComics viewer, which doesn't need any stretch to fit assistance.
I tried it, and it mostly works as you'd expect, but while Hungry Shark stretched nicely, the outer 1" on both ends of the screen didn't refresh right and things in the game just sort of disappeared.
Reactions: NHBass39
annahernandez51
