speaker phone problem
evoldroid
331
12
Can anyone tell me how to stop my phone from going to speaker mode everytime i answer it?
make sure you are not hitting it when you answer your phone.
If you are not selecting it,it sounds like a software glitch. The easiest way to solve this problem is just to hard reset your device. If your contacts are not backed up to your google account, back them up onto your sd card.
hope this helps.
I have seen this problem with other devices before but not with the s2. I looked around and there are some having the same problem.
