SPen Screenshot Problem?
fade2black101
116
Hi guys
I use the SPen frequently to outline and box something I want to take a screenshot of so I can send on whatsapp, etc. When I first got the phone, after I used to do the outline it came up with the message in the notification bar which enabled me to quickly go to the picture I just saved. For some reason this no longer happens and I can't find a way to get it back. Can anyone help?
As a sidenote, whenever I take a normal screenshot or do a screenshot gesture, it comes up with the message in the notification bar allowing me to go to the picture. This problem seems specific to the spen "outline" screenshot.
Thanks in advanced for any help
Do you have spen pagebuddy turned on?
Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
