SPen's friction causing paint inside my Note 5 to fade away.
kingredfire
8
Is it just me or is the paint inside the insertion point for the SPen white unevenly. I am aware there are other white etches inside this part, but this one bothers me because it is uneven. Can you please take pictures of your SPen insertion holes please? 😆
Thanks,
A Concerned Note 5 User
I think that's normal. I can see white plastic color with a few small dark colored vertical lines. Likely this part of the phone was not painted, so the chance of paint rubbing off should not be there, as I don't see any paint marks or discoloration on the S-Pen that would indicate paint rubbing off from the S-Pen home. I don't think the color difference is anything to be concerned a out.
glastek15
