SPH-L710 None spark Boost i think
Ray Correa
4
Hi,
I have a boost S3 SPH-L710 phone that came with ICS and updated to kitkat 4.4.2. I think it came with ICS i am not sure though.
I am trying to load Lolipop 5.0 or 5.1 roms and none of them work. I do a system wipe, download both S3 Boost
& Sprint S3 roms and nothing works. I load the rom and it boots to the boot screen ie name of the rom like ACID or Liquid Smooth and it just stays there. I tried different recoverys like TWRP, CWM and Philz, updated tars to ND3 and the newer one. I am able to flash kitkat roms no problem just Lolipops.
I tried wipe Divek cache/cache and repair permissions, edit update script all that nonthing works. Any suggestions
This is the model i have, hope it helps
Samsung Galaxy S III (CDMA)
Specs Compare side-by-side vs...
Modes
more detail
LTE 25 / 26 / 41
CDMA 800 / 850 / 1900
US Cellular version adds CDMA 1700, LTE 700/850/1700 / older Sprint versions only support LTE 1900
Weight 4.65 oz (132 g)
Dimensions 5.38" x 2.78" x 0.34" (137 x 71 x 8.6 mm)
Battery Talk: 9.2 hours max. (552 minutes)
Standby: ?
2100 mAh LiIon, Removable
Display Type: OLED (Full-Color)
Resolution: 720 x 1280 pixels
4.8" diagonal
Colors: 16.7 million (24-bit)
Samsung Super AMOLED
OS / Platform Android
version 4.0 (Ice Cream Sandwich)
Processor 1.5 GHz Qualcomm Snapdragon S4
dual-core
Memory 16 GB internal storage, raw hardware
12.1 GB internal storage, available to user
2 GB RAM
or 32 GB storage
SIM card size Micro (3FF)
FCC ID A3LSPHL710 » (approved Jun 1, 2012)
A3LSCHR530 » (approved Jun 28, 2012)
A3LSCHR530M »
A3LSPHL710T »
kankuraon
