Spigen Thin Case... design problems!
Climb14er
810
3
18
Been using Spigen Thin Cases for my Note Phones the last number of years since the early release of the Note 5. No problems, great cases. These current Spigen Thin cases for the Note 9, many folks including yours truly have experienced the bottom corners cracking and splitting under easy, normal use. There's a design or manufacturing problem that Spigen doesn't recognize exists. My case in particular, after two months of easy carrying in a leather belt holster, the lower left corner just sheared off... no drops, no harsh treatment. Spigen simply blew off my concerns and report! As mentioned, other people experienced the same. Spigen acted very cheaply in not offering any remedy. I even ordered a replacement before I discovered others with the same problem. NOT GOOD customer service policy on Spigen's part!
Which case, the Thin Fit or the Thin Fit 360?
I didn't get the Thin Fit, which I usually do, because the one for the Note 9 was made with slits on the corners.
I image that's where your case failed.
Thin case. Case failed on the corner, just broke off.
My neo hybrid is doing the same thing. I've went through 2 now with little to no bumps at all and this corner just falls right off.
NetspendLink
