Spigen thin fit compared to S7 Edge thin fit with pics
Kevin OQuinn
AC Team Emeritus
May 17, 2010
9,267
496
I got the Spigen thin fit in much earlier than expected.
Just thought I would take some comparison pics next to the same exact case for the S7 Edge. It seems that the Note will have far less pronounced "edges".
Note 7 case is on the left in these pics.
It does seem like the curved edges will be much less-pronounced compared to the S7e.
I know some people are concerned to see the curved edges, but maybe this will help a bit in knowing how it might be like.
How much was this case? Mine S7e case was like $7.99 from Amazon and its the same as yours.
Great pics! A less pronounced edge would be greatly welcomed
Thank You!!! Great Pictures. you kind of get the since of the size difference.
Thanks for this. Good for prespective on size btwn the two as well. Sort makes me wonder if I need to go with a thin fit case now. The tough armor might be gargantuous.
Hmm, I was looking at the renders and it seems like the Note7's curved edges are slightly less pronounced than the S7 edge. There also seems to be less display area on those curved sides compared to the S7 edge.
The S7 edge is on the top. The Note7 is on the bottom.
Spigen Slim Armor.
I'm still kinda torn over which case to get. The Neo Hybrid or the Tough Armor.
Decisions, decisions...
These are the exact two I am trying to figure out. I have never seen the neo hybrid in person but some reviewers say the bumper makes a phone "wider"? I think I might prefer the slim armor too but it doesn't seem to be at a discounted price on Amazon.
Yeah, I've asked my friends over which one to get. Most of them said to get the Neo Hybrid, which I love the look of, but I also like the kickstand on the Tough Armor.
This is tough...
Oh, and I'm going with the Gunmetal design if I decide to pick either.
This is tough...
View attachment 233392View attachment 233393
One has better drop protection than the other.
So I think I might go Tough Aromor with Kickstand because I think I may actually use the kickstand. And then also get a Thin Fit to use when I can't have a bulky case e.g. wearing a suit etc.
I do something similar. I use the Thin Fit in my car with the magnet mount. I have the metal plate attached to it.
Most other times I have a dual layer case or at least something on it that has better drop protection.
Is this the same case? I just ordered it in the blue/
https://www.amazon.com/gp/product/B...ag=hawk-future-20&ascsubtag=UUacUvbUpU5303612
