Split Display Issue
Sam1224
Active member
Apr 5, 2013
36
Nexus 6 Marshmallow 6.0 Build MRA58K
Since the update a week ago, my phone has inexplicably begun randomly vertically splitting the display. Usually happens when scrolling through my twitter feed, but it has also happened while using a couple other apps. I've tried capturing screen shots of it when it happens but the screen shots appear normal once I reboot and can go look at them.
In Twitter, the screen will appear split precisely down the middle and will not sync back up. If I navigate to the home screen, it appears in quadrants. Functionality is there (to reboot the phone via widget) if I choose the correct quadrant and a reboot is the only thing that seems to remedy this.
It doesn't crash the phone or generate a bug report, it will happily sit like that for a couple hours if I leave it alone. Has anybody seen anything like this before? Any idea on a fix?
Forgot to note that I have had the phone since June and never experienced this issue under Lollipop.
zolepso1
