Spotify battery drain
Prath09
64
3
8
Hi all. Was wondering if anyone had similar issue with Spotify draining their battery. I played music for about hour or so and it drained 9.9%. Is there a way to fix this?
Yes, listen to less heavy metal music! Seriously, I use Spotify and haven't noticed any abnormal battery drain. Of course, you can always remove the app, then reinstall.
Heyan
