Sprint Galaxy S3 Problems... HELP!!!!!!......
Gleibis Leon
My phone is driving me crazy. My play store does not wants
to work. I can't do any updates or downloads, what should I do?........:'(
Try doing this:
Settings
Application Manager
Find Google Play Store
Click Uninstall Updates
Restart Phone
Do you see your apps? If not go to settings /accounts and delete Google. Then add it back.
Sent From The Galaxy VIA Subspace
If your date and time are off, it will cause a problem. As was discussed in another thread, resetting the date and time solved your problem for many on this forum. Later, Ray
cambium
