Start up problem!!!
sutton241
13
When starting my note tablet it take a long time to boot. It repeatedly shows Samsung galaxy note 10.1 2014 edition for about 5 to 10 minutes then eventually boot up. Does anybody have a fix.
Sent from my Galaxy Note 2 using Tapatalk 4
IF there is one in it try taking the memory card out!
If that does not work I think you are stuck with a factory reset, I have heard of no other way.
Press and hold Volume Up key + Power key.
- Keep pressing the above keys until the Samsung Logo appears,Then release Power key only.
- When you see Factory reset / System Recovery menu on screen release the Volume Up Key.
- Use Volume Down key to select Wipe Data / Factory Reset option.
- Use Power key to confirm the operation.
- You need to use the Volume Down key again to select "Yes -- delete all user data"
- Use Power key to confirm.
- After performing the hard reset, Select Reboot System Now option, And confirm it using Power key.
Keep in mind you lose everything you have done if you do a factory reset. It's the only way I know though, this is hitting many people for a high end tablet, I love the thing but they better come up with a fix soon or they are going to lose sales. I've been through 3 of these tablets and five resets, so far so good on the latest one.
Before deleting all data I'd try deleting just the Cache first... Also, pressing the Power DOWN button instead of Up, will get the tablet into 'Safe Mode'. If there's a pesky routine keeping the device from booting, this mode should boot faster and helps debug things a bit.
ManboaMaleManboaMaleEnhan
