Stock Nexus Help
mike.mercer
Active member
May 26, 2010
28
Ok so here is the problem. i have a stock non rooted nexus with a broken screen and nothing displays on it. and when i plug into computer it pulls up phone to a empty folder. is there anyway with out being able to see anything on the screen to either push CWM to it or to somehow using adb to pull everything off of the sd card???? my only other thought was to take apart phone and remove the piece of board with the sim card and scan disk chip and put it into a diff phone to try and move the data off but unsure if that would work. i am not sure if this will test the knowledge off ppl out there but it has surpassed mine.
that is a grat tool kit but i think where the problem is that it is not in debbugging mode and it is not rooted. thanks again though. i will be keeping this for when i get my own Nexus. i am working on someone elses
Yeah, no debugging mode is pretty much a killer. Maybe some sort of GN wizard will know what else to do, but I think you're boned.
smartcooky
