Straight Talk MMS problem for Tmobile Samsung Galaxy s 4G
mclanso
I have a couple questions in regards to using the Samsung Galaxy S 4G with StraightTalk Service. I was previously using my GSM Samsung Galaxy S 4G (Model T959V ) on the Tmobile network and decided to switch so I bought the StraightTalk/T-Mobile sim card. When I put it in my phone (after porting number), I am able to make phone calls and get SMS messages. However, data/MMS messages keep messing up. I have used the recommmended APN settings from straight talk and still doesnt work. It also jumps between Tmobile and Straight Talk APN setting. Here are my APN settings that i am using for Straight Talk:
APN: wap.tracfone
Proxy: not set
Port: 8080
User name: Not set
Password: Not set
Server: Not set
MMSC: http://mms.tracfone.com
MMS Proxy: not set
MMS port: Not set
MCC: 310
MNC: 260
Auth. Type: None
APN Type: internet + mms
Not sure what is wrong and could definitely use some advice. Thanks
Mclanso
make sure you delete all apn settings and start fresh. it finally worked for me. woo hooo. good luck.
APN: wap.tracfone
Proxy:216.155.165.40
Port: 8080
User name: Not set
Password: Not set
Server: Not set
MMS Proxy: 216.155.165.40
MMS port: 8080
MCC: 310
MNC: 260
Auth. Type: pap or chap
BUT I AM STILL TRYING TO FIGURE OUT HOW TO RECEIVE AND SEND MMS MESSAGES. CALL STRAIGHT TALK AND THEY TOLD ME I HAD TO CALL THE PHONE'S MANUFACTURER TO GET HELP AND THE STRAIGHT TALK SIM CARD I BOUGHT HAD A CONTRACT THAT SAID THAT POSSIBLY NOT ALL FEATURES WOULD WORK....WTH?
backbiomereview
