Strange battery behavior
BlackRA
Hey,
So i have a problem. Every time i charge my phone (M7) it says it 100% and the light on top is green but when i plug it out it drains super fast to 80% (30 mins or so) and then normal drainage.
But when i charge my phone at 100% and unplug it and then plug it back in it goes to 80% and continues to charge.
Maybe someone else will offer you another option, but there was a thread shortly after the update to 4.4 that talked about an issue similar to this one. The solution for several in that discussion was a factory reset. It worked for me. There where some other solutions to similar issues that came out either in that thread or another one with a similar topic. Below is the tread.
http://forums.androidcentral.com/ht...90-very-quickly-then-90-down-more-slowly.html
thegdduide
