Strange Problem after flashing CM7
wgilles
63
I flashed CM7 last night and everything is great with it except that SMS messages are not sending correctly. They send as blank messages no matter who i send them to. MMS messages send fine.
Any ideas?
You don't have to but if your not set up all the way might as well. If doesn't work I recconebd a clean Odin wipe with reparation pit file. Than work way back up to cm7 should take care of everything
What is a repartition pit file?
When I installed CM7, I did an Odin stock Froyo install, re-rooted and installed CM7.
I ended up flashing the DL09 radio and SMS works now...
Anyone know which radios you can use with CM7?
Thanks for the help everyone. After I did the DL09 radio update, I updated the radio to EC09 and everything is working great now.
I ended up not having to reflash, I guess it was just the radio. However, having those files to future use when reflashing anything is a big help, thanks a lot, bigj.
stoffe949
