Stuck on load screen after flashing
imarx
Active member
May 7, 2010
25
I rooted my AT&T One X and installed TWRP without issues, but now whenever I try to flash a ROM and reboot it gets stuck on the ROM loading screen. I have tried both CM10 and AOKP using both TWRP and GooManager but get the same problem every time. Does anyone have any suggestions for what to do?
cbatiste1993
100
4
Did you flash the boot.img through fastboot before flashing the ROM?
Sent from my HTC One XL running ViperXL 3.0.0 using Android Central Forums
imarx
Active member
May 7, 2010
25
No, I got the impression that you didn't need to flash boot.img if you were using TWRP. Do you do that before flashing the ROM? If so, how do you get back into recovery after flashing boot.img?
Bizzle69
681
4
(Even though you may have done these steps, DO THEM AGAIN)
Do a factory reset, wipe system (this is important), reboot to bootloader>fastboot flash rom, flash it again in TWRP...
Needing to fastboot has nothing to do with what recovery you use, it's because you have hboot 1.14 is the need to fastboot flash then TWRP
EDIT: to get back to bootloader, hold power button and volume DOWN (not up).. As soon as the phone reboots, let go of power button, but keep holding down the volume DOWN button
prissysox
Trusted Member
Jun 11, 2010
1,246
12
Trying again. *Fingers crossed*:confused:
Still stuck on CyanogenMod spinning screen. Been there for over 20 minutes. How long should it take? How many tries?
imarx
Active member
May 7, 2010
25
Thanks for the help. I actually ended up flashing CM10 and Gapps first through TWRP, and then flashed the boot.img through fast boot which worked perfectly.
Shiny_2084
