stuck
Pam Finch
How do turn back on the weather information on the weather bug widget on the lock screen note 5
I currently have the weather/time on my Note 5s lock screen but it is running Lollipop. They took away the weather on the lock screen if you have upgraded to Marshmallow.
I have weather bug on my lock screen running 6.0.1
Let me go look and ill post the answer in a min.
** go to settings, lock screen, notifications on lock screen, make sure weather bug is turned on.
Again this is 6.0.1.
Hope it helps.
Sent with my white Note5 with nonremovable back and no SDcard!
I reinstalled the app on Note 5 and I have the weather info as a notification. Try reinstalling it like I did and see if that helps. IF you install the weatherbug app and not the widget, you get the weather on the lock screen.
Side note, weatherbug is a great app, inuse it because i need wind speed and direction sometimes and not all weather apps have it.
sportzfyapp
