SU permissions problem
Fazulka
135
10
First, my hero is rooted with and running option 3 from the old 2.1 leak. I did flash the radio update someone removed from the new RUU.
Today I tried to do 3 things that require root. I attempted to use the over clock widget for the first time. When I tried to use it the screen turned black with a gray bar at the top that said "SU request" then nothing else happened. No option to grant access or deny.
Later, I decided to try a new ROM, to I bought and d/l'ed MyBackup Pro. Same problem, it recognized I had root access, but stopped working with the black "SU request" screen.
After that I tried "Shootme" which requires root access and took this picture so everyone can see what I'm talking about:
Thanks!
if the USB debugging IS on then reboot. still no? then try uninstall/reinstall shootme or overclock. that should reset it so the screen will come up again. then you can click allways allow.
Thank both of you for responding. It was the USB debugging that was off.
Thank you!
nysmarkets
