- Jun 7, 2013
- 3
- 0
- 0
Over the past few days my sgs3 has inexplicably been having battery issues. When I check the battery status, the phone states the the screen is the biggest culprit and responsible for about 50 - 80% even when the screen has been seldom on. What's worse is that even though the screen hasn't been on the phone is pretty much always awake for some reason. When i check task manager no apps are active. TO help pinpoint the problem I downloaded wakelock detector and it revealed that the android system was keeping the phone awake and more specifically the location manager service . I tried disabling gps and the automatic location updates for google maps and other apps but it did not fix the problem. Another issue to note is that the phone gets very hot sometimes (as high as 104 degrees) even when I'm not using it. Has anyone else had this problem and does anyone know a solution?
