sudden battery drop
Pengwn
Active member
Jun 22, 2011
34
Hey all, anyone else ever find your battery go from full to empty?
I tried rebooting and a battery pull thinking it might just be a software glitch but it wasn't.. it died on my way home.
Any thoughts?
Actually I had a similar thing happen to me, I just thought it was a program that didn't close properly; so i ended up doing the same as you with the same results.
It's working fine now, just the one time, so who knows what was happening.
This happens on any Android phone every once in while. I suspect it's related to some runaway app. A battery pull always fixes it for me, though I do leave the battery out for a minute or two. If it turned out to be a persistent problem that would not go away, I'd do a factory reset. If you happen to be rooted, you could reboot into recovery and clear cache and dalvik.
Gailweeks
