Sudden huge bluetooth battery drain.
kide#WN
637
845
93
Have my S6 since the release day. Have the Android wear watch and few other devices connected from the day one. Never had any issue with the battery drain caused by Bluetooth. Suddenly few days ago the battery started discharging at very fast rate and the Bluetooth is a top contributor. I tried to clear the cash, restart Bluetooth, reboot the phone, disconnect the Moto 360 watch, nothing helps. Even the latest 5.1.1 update from AT&T didn't solve this issue.
Any suggestions?
Thanks
Hi, I don't have a solution, but I do have the same issue. I received a software update last week, which on first glance only changed the app icons to look similar to the Note 5, but now my bluetooth is draining my battery. I stream music in my car and it's taking its tole on my battery all of a sudden
In my case it drains even if no devices are connected, only paired.
Turning Bluetooth off stops the drain.
Same issue with a Nexus 5 last 3 days. Last week it was outlook contact synchronization locking up the contacts book causing Android Core Apps to battery drain. Wish Google showed you when you last updated an app vs. "recently" so I could go back three days and disable any app updated that day as process of elimination.
My wife's VZW S5 started doing this last week while refusing to connect to her Fitbit. Also heats up her phone. We had been blaming a recent fitbit app update, but now starting to look like some Samsung bluetooth patch. Meanwhile, my VZW S6 is working fine.
I am having the same issue after upgrading to 5.1.1. The only thing I haven't tried yet is a factory reset.
It must be one of the downloaded applications. If I put the phone in to the Safe mode, the Bluetooth doesn't even appear on the list on the Battery page.
Did a factory reset and now Bluetooth is not draining my battery.
How long have you been running without battery drain? I really don't want to factory reset, but I may have to.
Sent from my SM-G920V using Tapatalk
