Sudden Issue Charging
Hemdroids
23
Probably will bring it in soon, but wanted to see if anyone has had a similar issue first.
Went to bed last night with my Z3v on its wireless charger, not sure if it was charging at that point. Woke up this morning and the battery was low, figured I just had it on a bad spot on the charger. Tried moving it around, nothing. Thought maybe it was an issue with the wireless charger so I tried charging it with the wire. When I connect it it beeps to indicate its charging, and then beeps again a couple of seconds later, and keeps doing that while the battery drains.
Anyone else have this problem, or know how to fix it?
#Hemdroids
Have you restarted the phone and had the same issue?
Have you turned the phone off and tried to charge it with the wire?
I tried both and had the same issue.
BUT, I just connected it to my PC using the same wire and it says its charging, thought the % just dropped 1 so I'm thinking it might be lying to me lol...Tried going back to the charger and had the same issue with the connecting/disconnecting.
Edit: Up 3% connected to the PC. Might be an issue with the charger, will have to try another one.
