A
Android Central Question
Hi there,
So today I am finally upgrading from my trusty S7, over to a new Galaxy S9 (couldn't afford the S10!) after numerous memory issues with the S7 which has resulted in me having to save my info all over the place!
Essentially I am constantly getting the memory full message, and when I do, I transfer stuff from the internal memory over to the SD Card. I have also found that when I open certain apps again, it transfers all the data back over to the internal memory which is a real pain!
Soooooo I have bitten the bullet and gone for a 256gb S9 which should sort that problem. What I want to do though is transfer everything back from the SD card onto the device so on my new phone its all stored internally and there is no need for an SD so I can use the extra slot for another (work) SIM. Is that possible? Is there some sort of android back up that will do this, or an app? Or do I just install file manager and transfer everything from the SD card onto the phone that way?
Essentially what is the best software or app to back up and re-install data onto a new handset?
Thanks,
Alex.
Thanks,
Alex.
