Swipe pad: could it drain battery?
pcguys
596
8
I installed and really enjoyed SwipePad:
https://forums.androidcentral.com/e...duction.swipepad.android&hl=en&token=QzaHjTUA
Something over the weekend was draining my battery, so to rule it out, I disabled swipepad.
Question: because the app needs to constantly watch for you pressing a certain area of the screen, is that likely to be a battery killer?
Just curious; at some point, I'll re-enable it and see if the drain comes back.
Mike
I've been using it for a few weeks. Yes, it runs all the time in the background, but it doesn't do a whole lot. I haven't seen any effect on my battery. Perhaps you have installed another app that is harming your battery or changed settings on an existing one.
I wonder if the act of constantly monitoring which pixels on the screen are pressed is a function of the OS/Kernel and not individual widgets?
My gSam battery monitor was complaining about the kernel, and not this app by name.
In any event, after a very good battery day yesterday (down only 30% in 16 hours), I turned swipepad on now and will see how I do today!
Mike
thegdduide
