SWM issues with Sony X10
jimdon
I am trying to use the SWM with a Sony Xperia X10. I have downloaded all the latest software from the Sony website and still can't get SWM to run - I get the error: device not found and also under troubleshooting I do not see a serial number when I run the diagnostic. I have checked the driver under device manager and it appears to be working. I have followed all the steps in your documentation and still doesn't work. My computer is running Windows Vista and my phone is Android 1.6. When I mount the phone I can see the adk files, etc. but they will not load. Please advise.
Thanks,
Having the same problem
I have the same issues you do, jimdon. I have an AT&T branded SE Xperia X10. I absolutely love this phone, but I can't upgrade from 1.6 :'(. Have you found an answer to your question elsewhere?
same problem here, at&t they had new 2.1 update and it now won't allow any of my paid apps or apps period that I backed up to download back into phone, "blocked files not native to android market" which is a load of crap cause use nothing BUT that. So tried this program to get them back on it and yeah device not found and i have all the drivers etc and running windows 7
The problem I am having is trying to get Backup and Restore to work. I don't get the settings button that the Sony Companion says I am supposed to get. Is there a way to bypass it?
Ok I WAS having the same problem, but I found version 1.1 beta worked!!!!! I'm sooooo happy now. It found my X10 and installed my FPse and now i'm playn FF7 :):):):):):)
Hello,
I also have the xperia X10 with at&t and keep getting the 'device not found' error. I tried the beta and get the same results. I tried two different cords in two different usb slots. I can see the phone in the device manager. I have tried to update the driver many times, and I am supposedly updated. I am sure it's in charge only mode and disabled all my installed apps. USB debugging is enabled. I searched the internet for newer drivers but only found some on the Sony site from July 2011. That is installed. I am using Windows XP and did downloadand install .net framework 4.
I am trying to use the avast anti-theft and it requires the non-market apps to work.
Any help appreciated.
Thanks.
siratguidance56
