system/build.prop
JKChad
5
Has anyone played around with the build.prop yet. I know i always did with my org. Droid. Didn't see the need to so much with my X. Loving my Fascinate, but wish I could squeeze a little more out of the video camera settings.
Just looking through it I notice the settings are for the lower end of the video camera setings. I don't see the hprof.vid.width for 720? Anywho, I just rooted my phone about 2 hours ago. So, still lots to tinker with.
Post up any cool tricks you might find regarding the video camera.
-Chad-
I messed with my Droid X's, and the dang thing would never boot up again. Had to re-flash the .sbf. That's my luck though.
back up your build.prop with the original in your /system folder, that way if you crap it out and it wont boot, hold both up and down volume and power, recovery boot:
adb shell
su
/system
if you want to save the one your working on (mv build.prop build.prop.broke)
mv build.prop.bak build.prop
reboot and unbricked!
I do this daily to find how far I can push it
Same goes with any file you want to mod or change, just make sure there is a backed up file in the fold to make it all that much easier on you.
Some lines I have added, I think they work, they might, who knows.
ro.telephony.call_ring.delay=1000
wifi.supplicant_scan_interval=90
ro.mot.search.provider=www.google.com (uses google for regular search, dont know exactly as I have messed with a lot of stuff but only checked it after this)
mot.proximity.distance=60
mot.proximity.delay=150
ro.product.max_num_touch=3
ro.min_pointer_dur=10
then again I did fully remove the I500_bing.apk all together, that might be it, just another useless line of code.
WuijKaoila
