System ui battery overnight drain 50%
Approvoi
10
Since 2 nights ago, my overnight batt drain is greater than 50% more than the day drain. I installed batman apk and suspect that could be the cause.
Any experts out there to comment or had a fix
So, your battery drops by 50% overnight? Can you delete that install and then see what happens?
Please post a screenshot of your daily battery usage (found in your Settings app), so we can take a closer look. Thanks, and good luck!
Batman apk? A pirated batman game app? Probably the reason. Sometimes those stuff contain malware (viruses) that steal data or push ads.
battey life is pathetic. i charged fully at 4pm and its already at 56% just by lightly browsing the internet.
Since I'd know you will ask...
Same case again. Drop 30 % while I sleep. If you look at the chart it is steeper at night compared to day time.. Any comments?
I am removing the theme to see if it improves. Yes. It has live wall paper
Please let us know if that helps.
Live wallpaper tends to be a cause of battery drain in many cases.
Resolved after using a normal theme - sevenabstract. Overnight drain less than 10%. Compare the gradient of drain after 12am and above screen shots.
crawfish
