System UI Tuner?
NuMotiv
Active member
Mar 12, 2016
37
Has anyone been able to get it to work on the edge? I try and try and try and it just won't work. I wonder if it has to do with touchwiz?
Would be nice if we could get it to work so I can clean up some of these icons in my status bar.
Yes thats what I'm after. No more vpn key and to put the battery percentage in the battery its self.
i as well would like to see this feature for my note 5 hate the vpn key, and would like the batteey percentage inside the battery
I've tried unsuccessfully too and am under the impression it will not work on some, if not all, Galaxys. It's mentioned in other posts but if anyone could confirm either way, it might be a help
I heard that Samsung, HTC and LG didn't include the UI tuner in their Marshmallow update.
MorriTinni
