System UI volume
sicario666
2,932
366
83
Is there a UI volume setting on this device? I'd like to turn it up a bit louder. I used search in settings but couldn't find anything
Are you talking about sounds like the ones you hear when tapping on-screen system buttons? On my Pixel 7 Pro, that's actually associated with the Ring volume. But the sound is pretty soft and innocuous by nature, so at its loudest, it's still fairly soft. There's no way to change the sound as far as I know -- if there is, it would probably require rooting.
Yes exactly what I'm talking about. The sounds are low, I was hoping for a louder setting but I guess I'm out of luck. I like to hear what in tapping as well as the lock sound
omertasociey
