T-Mobile and 4G LTE Data Issue?
searchmaven
14
The last couple of weeks my T-Mobile branded M8 will have full 4G LTE bars but completely lose its data connection. Rebooting the phone will reconnect to LTE data but only temporarily before it's lost again. Changing the connection to 4G-only results in consistent data connection without interruption so I'm guessing the issue has something to do specifically with T-Mobile's LTE backend. Anyone else on T-Mobile experiencing this?
I have. Only a few times. No clue what the cause is.
Sent from my HTC One_M8 using AC Forums mobile app
I have. It's pretty annoying so I hope that they'll find the fix soon. However, instead of restarting the phone I just turn airplane mode on and off. It's quicker I think.
Posted via the Android Central App using my HTC One (M8)
I think it is a phone issue. I purchased one from Sprint and had the same problem. Called Sprint and HTC about it and ended up sending the phone back to HTC. I am waiting on my replacement phone to see if the problem repeats itself. If if does I will be returning it, since it is my work phone and need it working.
Yup, I've had this issue. Like LelandC mentioned, turn airplane mode on and off and that seems to fix it.
I found a more reliable connection by creating my own APN and using IPv4. The default is IPv6. With 6 on i would tend to have LTE connection but after a while no data would pass.
On a more rare account, i have noticed when driving across cities my device might get stuck on 4G and NOT go back to LTE. Airplane mode helped me switch back to LTE but i still had data issues. Power cycling fixed it. However for me this has only happened a couple of times.
Lord Terox
