[T-MOBILE]No OS, Not Rooted?? HELP
cjmwid
6
So i have my HTC One, Its Unlocked, S-ON, and not rooted anymore(Somehow this happend) Im running TWP 2.6.3.0. I can adb push files to system and SDCard just not data....
When i try to Install a ROM after pushing it to the device i get the following
E:Unable to mount '/data'
E:Unable to recreate /data/media folder
Updating Partition details...
E:Unable to mount internal storage.
E:Unable to mount '/data/media during GUI Startup
E:Unable to mount '/data/media/TWRP/.twrps'
E:Unable to mount '/usb-otg'
And then it just keeps going with /data
I tried to use ADB Sideload with TWRP and it FAILED
All Versions information
version: 0.5
version-bootloader: 1.55.0000
version-baseband: 4A.21.3263.03
version-cpld: None
version-microp: None
version-main: 3.24.531.3
version-misc: PVT SHIP S-ON
serialno: FA3A5W901239
imei: 355972051273473
meid: 00000000000000
product: m7_ul
platform: HBOOT-8064
modelid: PN0713000
cidnum: T-MOB010
battery-status: good
battery-voltage: 3872mV
partition-layout: Generic
security: on
build-mode: SHIP
boot-mode: FASTBOOT
commitno-bootloader: dirty-412e361e
hbootpreupdate: 11
gencheckpt: 0
Would like to get it back to STOCK or a good ROM running 4.4.
Thanks,
Charles
If anymore information in needed please ask!
Edit: I can mount Cache and System via TWRP Mount option
version: 0.5
version-cpld: None
product: m7_ul
modelid: PN0713000
cidnum: T-MOB010
security: on
build-mode: SHIP
boot-mode: FASTBOOT
hbootpreupdate: 11
gencheckpt: 0
Thanks,
Charles
So when you try to install a rom, it doesn't flash?
It will flash recovery, have not tried anything else as i have no clue how to do the rest??
adb flash system ROM.zip
Im guesing thats right then i would clear the cache?
Thanks,
Charles
Thanks,
Charles
You said you can mount the phone in recovery right? Can you find the device on your pc?
Sent from my HTC One X using Tapatalk
No i cant, i can push and pull files via adb
Edit: In my Device Manager it does see 'My HTC' cant access files or anyone
Not sure if any of this will be usefull
Boot/Recovery signature checking...
TZ_HTC_SVC_HASH ret = 0
setup_tag addr=0x80600100 cmdline add=0x003F2B38
TAG:Ramdisk OK
TAG:skuid 0x38929
TAG:hero panel = 0x940074
TAG:engineerid = 0x0
TAG: PS ID = 0x0
TAG: Gyro ID = 0x2
TAG: Compass ID = 0x0
TAG:NFC RFID 0xFFFFFFFF
Device CID is not super CID
CID is T-MOB010
setting->cid::T-MOB010
serial number: FA3A5W901239
Device CID is not powerkey debounce CID
commandline from boot/recovery image header: console=ttyHSL0
,115200,n8 androidboot.hardware=qcom user_debug=31
active commandline length = 908
active commandline:
poweron_status=1
reset_status=0
board_m7_ul.disable_uart3=0
diag.enabled=0
board_m7_ul.debug_uart=0
userdata_sel=0
androidboot.emmc=true
androidboot.pagesize=2048
skuid=0
ddt=20
ats=0
dap=6
androidboot.lb=1
uif=@000
td.sf=1
td.td=1
td.ofs=328
td.prd=1
td.dly=0
td.tmo=300
hlog.ofs=628
un.ofs=696
imc_online_log=0
androidboot.efuse_info=4FSL
androidboot.baseband=4A.21.3263.03
androidboot.cid=T-MOB010
androidboot.devicerev=3
androidboot.batt_poweron=good_battery
androidboot.carrier=TMUS
androidboot.mid=PN0713000
androidboot.hasfp=0
enable_zcharge=33
androidboot.keycaps=qwerty
androidboot.dq=PASS
androidboot.mode=normal
androidboot.serialno=FA3A5W901239
androidboot.bootloader=1.55.0000
lscd=0x1
wificd=0x1
androidboot.nledhw=0
androidboot.ddrmid=(0x3)
acpu.footprint=FF010101
abnrst=0
zygote_oneshot=off
kmemleak=off
rpm_debug.enable=0
console=ttyHSL0,115200,n8
user_debug=31
setup_all_partition_atag:
Partition[0].name=misc
Partition[1].name=recovery
Partition[2].name=boot
Partition[3].name=system
Partition[4].name=local
Partition[5].name=cache
Partition[6].name=userdata
Partition[7].name=devlog
Partition[8].name=pdata
Partition[9].name=extra
Partition[10].name=radio
Partition[11].name=adsp
Partition[12].name=dsps
Partition[13].name=radio_config
Partition[14].name=modem_st1
Partition[15].name=modem_st2
Partition[16].name=cdma_record
Partition[17].name=reserve_1
Partition[18].name=reserve_2
Partition[19].name=reserve_3
Partition[20].name=reserve
Valid partition num=21
setting_get_bootmode() = 2
smem 84505000 (phy 8F205000): TZ_HTC_SVC_UPDATE_SMEM ret = 0
TZ_HTC_SVC_ENC ret = 0
Start Verify: 3
TZ_HTC_SVC_DISABLE ret = 205643776 (0xC41E000)
[PARTITION_ERR] partition_write_prot_emmc: Cannot find end p
artition [modem]
msm_mpu_emmc_protect: set write protection fail (from reserv
e_2 to modem)
Start Verify: 3
[RUMBA_S] firmware version: 3-46-43-33-0-0-0-0
[RUMBA_S] ondevice version: 3-46-43-33-4-35-A2-0
[RUMBA_S] firmware version already up-to-date
pm8921_vreg_disable function, vreg_id = 7
pm8921_vreg_disable function, vreg_id = 37
pm8921_vreg_disable function, vreg_id = 34
pm8921_vreg_disable function, vreg_id = 8
jump_to_kernel: machine_id(4308), tags_addr(0x80600100), ker
nel_addr(0x80608000)
-------------------hboot boot time:8525 msec
What commands are you running?
All you need to do is copy the rom into the folder on your PC that has fastboot & adb in it. In recovery on the phone start adb and the type this in a cmd promt opened from the fastboot folder "adb sideload nameof rom
He was unable to do that.
TAG:Ramdisk OK
TAG:skuid 0x38929
TAG: PS ID = 0x0
TAG: Gyro ID = 0x2
CID is T-MOB010
active commandline:
poweron_status=1
reset_status=0
diag.enabled=0
userdata_sel=0
skuid=0
ddt=20
ats=0
dap=6
androidboot.lb=1
uif=@000
td.sf=1
td.td=1
td.ofs=328
td.prd=1
td.dly=0
td.tmo=300
hlog.ofs=628
un.ofs=696
imc_online_log=0
androidboot.hasfp=0
enable_zcharge=33
androidboot.dq=PASS
lscd=0x1
wificd=0x1
abnrst=0
zygote_oneshot=off
kmemleak=off
rpm_debug.enable=0
user_debug=31
Start Verify: 3
artition [modem]
e_2 to modem)
Start Verify: 3
Strange. You should be able to access the internal storage... Hmmmm.... Can you at least see the content inside?
I can use the TWRP File Manager to view the files.
My Computers sees that its connected just cant open the SD Card on my pc...
Now i cant mount Cache only system
#Request CLOSE
I got it back to factory settings(Thx HTC Live Chat!)
I had to RE-lock my phone, download the RUU from HTC's Site, Let it do its thing while in FASTBOOT USB. Took about 10 mins and it was done, fully working....
Thanks,
Charles
#Request CLOSE
Thanks,
Charles
Ahhh, the famous RUU...
