T-Mobile V20 Owners: MMS Help
sniperservice
79
I am able to send MMS, but am not receiving them. I have already switched to the SIM Card that came with the phone and did a Factory Reset. Any advice or solutions? Outside of this, I am absolutely happy with this phone
I've had similar issues jumping from my old iPhone over to Android. Didn't appear to be device specific as I experienced the issue with both my Note 7 and S7E. Read some online sites that suggested it was a known issue with iMessage users.
Will be curious to see how it behaves when my v20 arrives this week.
I've had this issue with another phone after switching but not this one. If restarting doesn't work a call or trip to T-Mobile will fix it.
If switching from iPhone, there is a procedure to remove your phone number from imessage. Sometimes it plays havoc
https://www.google.com/search?q=remove+phone+number+from+imessage&oq=remove+phone+&aqs=chrome.3.69i57j69i59j0l2j69i60.4108j1j4&client=ms-android-hms-tmobile-us&sourceid=chrome-mobile&ie=UTF-8
Check your APN settings. Ensure they're setup properly for T-Mobile.
Do you not receive them at all or are they coming in but saying tap to download but nothing happens when you tap them?
FahadsTech
