T95 Mbox android 10 problem with ATV Launcher Pro
Jason7319
Hi all,
I got given a T95 Mbox running android 10. Installed ATV Launcher Pro. Works fine when first start up, but I go into an app no issues. But when I exit the app to the home screen, the home screen will refresh, and continue refreshing every few seconds. Only things that stops it is restarting the box or disabling the launcher, then re-starting the launcher. I have also tried wolf launcher and same thing happens. Doesn't do this with the stock launcher. I have checked all permissions, looked in display, couldn't find anything. I am at a loss now, can anyone help with this problem please?
Welcome to Android Central! I moved this to the Android TV forum for more specific traffic.
It might be difficult to pinpoint the issue, since it could be a glitch with the box's firmware, or perhaps some conflict with some other app you installed. Since Safe Mode wouldn't help in this situation (since you're trying to test an app you installed), then the only other troubleshooting step I can think of would be to uninstall other apps one by one and see if the problem goes away.
Thank you mate. I am sorry for my late reply, I tried that box didn't want to play nicely, so ended up factory resetting again. It seems like resetting it a second time has solved the problem. Been using it most of the day and have not had a home screen refresh once. Hopefully, this has solved the issue permanently mate.
alejandro109322
