• Welcome to the all-new Android Central Forums! - We're still moving some things around, so you may see a few quirks here and there, but we're working on getting things fully completed as soon as possible. For now, take a look around, and if you run into any major issues, please let us know in this thread!
Tablet Fails to connect to network.Help!!
Erick3159
4
Hello
I have an Acer tablet and after a while using it it just disconnects from the internet and when I try to reconnect it can't connect to network. Please help this is really a bug problem.
Thanks
I got Acer Iconia A1-180
sauce_a_poutine
191
Many reasons could cause this. My hypothesis is that your tablet's software disconnects from the network by killing the Wi-Fi radio while not in use, but upon reconnection, your tablet wants to keep the same IP, because it noted the lease time on the previous IP, but the router, on it's side detected the disconnect and canceled your tablet's lease for that same IP. Call it a DHCP/client desync.
The best solution to avoid such problem, and increase your Wi-Fi security is to use your router's MAC address filtering system, and to reserve dedicated IPs for all the devices in your home.
This make DHCP desyncing impossible, and heightens your router's ability to stop unwanted intrusions on your network. You router's documentation can show how a MAC address white list is done and used, but if it is insufficient, many tutorials can show you how to do it.
Just Google or search Youtube for "Mac address filtering" adding your router or the word "tutorial" to the mix, and you should find ample documentation to do it in no time.
Erick3159
4
I have to restart my tablet so it can reconnect to the WiFi. My brother and my dad also have an android tablet and they work fine. I'm sure the problem its my tablet not the wifi.
Thanks
sauce_a_poutine
191
I'm not "blaming" neither device.
Sometimes the imperfection of our technology permeates in minor but routine-disturbing ways. I only suggested a hypothesis and a solution. Most tech problems can only be resolved by plausible scenario elimination, and the solution I suggested has a very high likelihood of solving the problem, even if what I've hypothesized as being a potential cause actually isn't.
That said, let's dig a little further... What is the make and model of the router ?
Erick3159
4
I have a 2WIRE AT&T router. But the weird thing is that my tablet also disconnects from the WiFi in McDonalds and all the wifi's I connect to everywhere I go.
Thanks a lot for the help I really appreciate it.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
161,949
293
83
Does your device have an Advanced Wi-fi-setting along the lines of "Wi-fi Optimization" or "Avoid weak signal"? Some of these advanced settings may cause the device to drop a connection if it deems the signal to be too weak, even though it might still be adequate for normal connection.
