TabS restore problem
PieMan123
Hi,
today I plugged my Tab S in to my PC and opened Kies 3, it said there was a firmware update. So I backed up my Tab S through Kies 3 and carried out the firmware update.
Now Kies 3 says "Connected device is supported through Smart Switch which is faster and more convenient" and won't let my Tab S connect. I have downloaded Smart Switch, but it says it is for sending and receiving data between devices.
Can anyone say how I can restore my data that was backed up through Kies 3.
Any help would be apreciated.
Regards
P
You can! Connect your device to Smart Switch on your PC, then select RESTORE. There, use the 'SELECT A DIFFERENT BACKUP' option and browse for the Kies 3 file.
johngrey
