tasker help
gillbie943
10
Now I know this is gonna sound really specific .. But i really want to know how to do this!
Soo I'm trying to create a widget for my homescreen that will activate a button within a 3rd party application.. So ideally I won't have to open the app to activate it!
I have successfully created the widget but I don't know how to create the activation task/ process.. Do you know what I mean??
I'm running cm10.1 on galaxy s4
Cheers
from my s4!!
I don't think that's possible, you have to open the app first unless that app can run in the background and receive remote commands.
You can create an automation where Tasker open up the app and tap on the button, then press back to go back out.
You simply use the "run shell" task, and use the command "input tap xxx yyy". X and Y being the pixel location of the screen. Also make sure root is checked.
This was how I set Cheapcast to automatically turn on itself after boot. But this is no longer needed since Cheapcast can turn on itself automatically now.
http://www.youtube.com/watch?v=Y_2rIyPO5IM
Cs Kredivo
