TBolt battery only charger w/Rezound
coolbreeze
273
7
Anybody using a Thunderbolt battery only charger with the Rezound? The one Verizon is selling as "Rezound compatible" is $30.
I have the Thunderbolt one and the battery fits, but I don't want to mess up my spare battery.
Anybody think it would hurt anything?
Sent from my ADR6425LVW using Tapatalk
Good deal. I got the TBolt one for $5, didn't want to spend $30 on one.
i used my 25% employer discount and got it for $3.75. if you work for a large employer, you should check to see if you qualify for discount. the $1.25 savings isn't much, but you do save typically 15-20% off your monthly voice and feature (unlimited data or $50 tiered data level, mhs, etc) on the primary line.
I get a 25% discount on accessories and 17% off monthly service. So it would be a little cheaper than $30, but no reason to get it if the Thunderbolt one works. Thanks for the suggestion though.
sukarisw15
