Text message audio alert problem...
aliasneo07
52
Hey all.
I have my message alert set to vibrate and audio, and it usually works. However recently it seems sometimes it will all of a sudden stop making noise, and vibrate only on text. Then I'll reboot my phone, and sometimes it will work correctly again, sometimes it will not.
Any settings I should check? I'm 99% sure I'm set right, but, this is really annoying. It just started happening over the last couple weeks.
Thanks.
Hey all.
Thanks.
If the notification sound is set to use a personalized sound, change it to a standard system sound setting and see how that works.
-Frank
Ishimwe
