Textra + Light Manager = No notification LED?
cedjunior
65
Previously the stock app + Light Manager worked fine. However, Now that I installed Textra there is no LED flashing. I've tried it with and without LED enabled in Textra. Are this apps just not compatible with each other?
Textra is listed as supported by Light Manager, however there is an asterisk beside it, indicating root only support.
I've been using Light Flow but perhaps a fellow reader has a solution for Textra and Light Manager when unrooted.
Makes sense. I guess I should read the fine print. Does Light Flow work with Textra without root? Didn't see it on Light Flow's web page.
I have Textra and Light Manager playing nice together with no problems. In the phones Settings, Notification LED, uncheck all the options except "Downloaded apps". Try that.
Yeah I did that when I first installed Light Manager otherwise the phone ignores it. Didn't seem to make a difference though with Textra.
Yes, I had Light Flow working with Textra (I say had only because I switched back to the G3 stock Messaging app). Textra is still installed, but just not my default SMS app for the time being.
nosrejocius
