The battery usage for my android system is 20% is that normal?
hawaiijedi
180
I did the update version for the rooted ego users and just was wondering if that system usage is a little high or not. Any feedback is appreciated.
the usage doesn't tell you much actually.
When it's low it means something else is using the battery more than Android system. i.e. the 100% battery is divided among all items using battery.
When it's high it means the Android system is using more battery than anything else (usually happens if you're phone has been idle for a while). high android system also means idle system not necessarily battery drain.
simply effective
